Originally Posted by Akimbeau
That's a good idea, changing out the pads for the track. The 6 piston brake kit does require cutting off the "ears" that hold the GM caliper to the spindle and then enlarging and tapping 2 existing holes. Less than an hour to do both I would guess. Does anyone know if the ERA front spindles are a stock GM item or do they make their own?
We've made our own uprights for about 10 years. Before that, we modified the Camaro ones by shortening the steering arm. The new ones use a bolt-on intermediate bracket that mounts the caliper. It's a relatively simple thing to mount almost any caliper as long as the offset is within specs.
