You might try to work with these guys if they are still around. Not sure how much variation there is on your bodies and setups vs what is available off the shelf. You may end up building a prototype set of pipes that fit just right, then find someone willing to produce them as needed or find a used set that fit and use them as the guide for more fabrication.
Good luck with your project. Looks like fun!
Stainless Specialties
