03-06-2016, 04:33 PM
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Originally Posted by steve meltzer
Thanx so much for all the input, guys. The "little white thing" is the alignment tool, showing that the shifter arms are indexed correctly, trans in neutral. First off, how do I set the limiting bolt, now that I've fooled around with it?. I'll check the the other things as well, and let you know. Great help! thanx again. steve
Added info for stop bolts in post #31 above. That white alignment rod/pin, did you have it thru all three shifter arms and housing side plates? silly Q I know, but I cant see from where I'm at!
Jac Mac
