Old 03-09-2016, 12:22 PM
1795's Avatar
1795 1795 is offline
Phil,
If you are not already planning on doing so, I would suggest that when you replace the intake manifold that you use RTV on the front and back instead of the cork gaskets. Sounds like you have a lot of work ahead. Make sure that there is no warpage on the heads and check the block to see if it was properly decked to begin with.
Good luck and keep us posted with pictures.
