Phil,
I recently pulled the heads off my car (ERA 797) with the engine installed. It was no problem, likely because I have studs that can be removed with the heads on the block, so the heads can then be removed. Do you not have studs? If not, I recommend you get the ARP head studs. They will make this work much, much easier in the future.
