Yes that was me that called. Since Danbury recommended the Cometic brand and size, in this case will stick with them. I have a 4.25 bore and the 1020 Felpros are for a larger bore. The thickness is .040 on the Cometic and .041 on the Felpros so not much difference that I can see.
Any thought on the exhaust gaskets? Seems to me the copper coated ones are thin and do not leave much for compression between the header and the head. I am a little concerned they will leak.
Phil
