Old 05-09-2002, 05:39 AM
Jim Downard Jim Downard is offline
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Hey Snake,
Something else you might encounter later ( or maybe not), but I'm running 15"x 9" Compomotive rims with 255/60-15 rubber, and when the rear suspension commpresses near to bottoming out, the tires rub the edges of my door latch plates. I don't know if this is only my car or if it has happened to others as well. I haven't done anything to fix it yet, but I plan to take my door latch mounting brackets and fabricate a jig based on the originals, then I'm going to make new ones with more curvature to allow clearance for the tires. Sometimes on really good g-outs I get nice little puffs of smoke from the tires. DV might have a better cure for this. Simply running smaller O.D. tires might cure the problem, but my original CR manual recommended the 255/60-15 tires at all four corners. This is really just a little heads up for a potential glitch. If you'll be working on door hinges, why not take care of the latch area also, right.
good luck,
Jim Downard
Man, it would've been helpful to know that cop was behind me a minute ago!
