Old 03-14-2016, 05:45 AM
1795's Avatar
1795 1795 is offline
Welcome on board, hope that you enjoy your ride. I use some rubber hose, the size that is typically used for vacuum hoses on carbs. It does protect the wheel spokes. Just cut off about 4" lengths and fish the safety wire through it. The good weather will be soon upon us.
Go over the car with a fine tooth comb to make sure everything is intact. These cars are not like standard cars, in which low mileage is a good thing. Low mileage in these cars means that the prior owner has not had enough time in the car to properly sort out any build issues that it may have. They all have at least minor build issues. Go slow until you get used to the power and handling characteristics of the car.
Good luck.
