Originally Posted by 1795
Go over the car with a fine tooth comb to make sure everything is intact. These cars are not like standard cars, in which low mileage is a good thing. Low mileage in these cars means that the prior owner has not had enough time in the car to properly sort out any build issues that it may have. They all have at least minor build issues. Go slow until you get used to the power and handling characteristics of the car.
Good luck.
^THIS!!
Also, your volt gauge, does it peg 15v or does it go 'almost' to 15v? If I am nost mistaken, you should be close to 14.7v while the car is running.
