03-23-2016, 12:06 AM
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Originally Posted by Scufty
SO ..Im building a 302 ..Before everyone gets on me about aluminum heads blah blah understand that these are a bunch opf parts that I am trying to put together a engine with for minor money.
Now.
I have a 74 302 block ..it was in good shape but going .40 over with flat top Hypereutectic pistons.
stock crank was in good shape so polish and back in. rods are fine - will go with ARP bolts. I would use 289 or Boss 302 rods (5.155") and skim ~0.035"/0.040" of the piston- that will get you piston out the top of block ~0.010" @ TDC for a piston to head clearance ~0.035" with a 0.042 gasket. If your getting brave on camshaft deepen the valve pockets at same time.
new bearings all round.
I have a set of good worked a little 351 heads from 1970. going to bolt them on and see how they are. ( I know ...just get Aluminum heads ) These are free mind you.
This is the Cam I have Ford M-6250-312 matched with lifters and springs.
then a performer intake a holley carb. Do the lifter bore groove mod ( you can buy the tool from Comp Cams or build your own if you have access to a lathe ) , check for lifter rotation when you do your cam pre-assembly checks, run the cam in with some light springs at first start for 20/30 minutes with a straight 20 or 30 oil plus zddp additive and 2/2500 rpm.
then headers (not sure what yet)
thoughts?
Thanks all who chime in
In text above.
Jac Mac
