You can test concrete compressive strength with a Schmidt hammer fro a crude reading. Otherwise coring out samples is required.
I just looked at the manual and it only needs 100mm thick 20mPa. Your slab wouldn't be less than 20mPa. I'm surprised that's all it requires with a few anchor bolts drilled in.
