Old 03-28-2016, 04:10 AM
jeffgrice jeffgrice is online now
Cobra Make, Engine: SPF Coupe #136, 427SR FI
Originally Posted by Brdslayr View Post
Looking to upgrade my car with shoulder harness. Only has the lap belts. SPO#2811. When going thru the wall behind the seat, is there one attaching point or two for the shoulder belts? Want to get it right the first time. I've seen both the double shoulder belt and one that goes over both shoulder and looks like a "Y".
The guys are correct - single bolt thru. There is a vertical piece of steel on the back side of the cockpit. Check it out with the car on a hoist. That is what you want to bolt thru. Be sure to measure both sides as the body could be a little off center when secured to the frame and since that is not a wide frame part you could miss center of it.
I used a marine grade eye bolt with fender washers.
Jeff
