Old 03-30-2016, 05:22 AM
DanEC's Avatar
DanEC DanEC is offline
DWRAT is 100% correct. Wiped flat tappet (mech and hyd) cams have become quite commonplace in the last 20 +/- years due to manufacture changes in motor oils to reduce zinc and phosphorus levels to protect catalytic converters. Some guys have wiped out 2 cams out in a row before finally biting the bullet and converting to a roller cam. A flat tappet cam will still work but you have to be careful with break in oil and then continue to run an oil with elevated ZDDP levels such as Rotella 15W-40 diesel oil, or Joe Gibbs, or Brad Penn oil. There are some others still around with high ZDDP levels but you have to do some research to find them or risk a very high likelihood of wiping a cam lobe or two out.
ERA 782 Running
