Thread: 351c help
Old 03-30-2016, 12:19 PM
blykins blykins is offline
The "4" on the front of the head next to the valve cover means it's a 4V head.
From what I've seen here on the dyno with factory heads and milder setups, you can easily make 400-420 hp.
You can also change the cam if you want to something thumpy.
If you do decide to change to a Windsor, the motor mounts and drivetrain will bolt right back up. Headers will need to change.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
