Guys, I purchased a Ford some time ago with a 427 side oiler / dual carb motor fitted, I had the engine professionally rebuilt (Over A$6k) including new pistons to run on pump fuel. The rebuilder dyno tested it giving 457 Ft-lbs at 3900 RPM and a max power of 425.6 hp at 5400 RPM. A colleague has offered to buy this motor from me however I am unsure of how much I should ask for it. P.S. the motor appears all original, c80e-6090-n heads with solid lifters, c5ae6300c steel crank, c2ae-6604-a
oil pump, c8ae 8505 h water pump and a FoMoCo aluminum intake manifold stamped 5-7-43. The block doesn't have any cast numbers other than a26.
