Hey Jim....Thanks for the info...I talked with DV today about the body prep...He know's it all and done it many times...he gave me some insight on how to mount the body....this should work real good. I'm using a vintage air heater system....just like Petek got in his.....right now, I've got 295/50/15 tires on 15X7.5 rims on the back, and on the front...I have 235/60/14 tires on 14X6.5 rims....looks realy nice. There just like the ones DV had on his blue Cobra....but I haven't mounted the door latch plates... I did check them for fit. That gave me a good indication that the body was pulled back at the right spot. DV told me to change my proportioning value so I bought the one he suggested from summit today. Thanks ED! If I have the same problem with rubbing...all probably do the same as you and what DV said....cut out the angle and weld a stock piece in it's place . Oh God.....!! I forgot to ask you DV...I don't have the switch that attaches to the brake peddal (brake peddal switch)...do you have one ...or where can I get one?
Thanks Jim...if there is any other suff...just bring it on...all help is helpfull!!
Thanks Again DV and JIM
