I have for sale or trade a temporary setup for staring and monitoring your engine during your chassis build. I used this for about a year while I saved $$$ for my body kit.
The setup is pretty self explanatory from the pics:
Bolt this unit to your top of your Bell housing using the top to bolts (My setup is a 351W and C4 Trans,.. probably fits others or easily adaptable). attach the Positve and Negitive Battery Cables to the switch. Flip the igition MAIN POWER to on (You will get the GREEN LIGHT),.. Pull Throttle Handle down 1-2 times to prime,. Hit the Ignition Switch. VVVVRRROOOOOOMMMM!!
All of this of course AFTER you hook up the SunPro
oil Gauge (No Sender Included), and the SunPro Temperature gauge. (Water Temp Sending unit included) and your coil. There is also an available mounting hole for your Electric Radiator Fan Switch (not inluded).
Ballast Resistor IS included.
What you see in the Pics is what you get.
MAKE ME AN OFFER ........ Cash OR Trades considered.
This is a very handy and compact unit. Complete,.. and out of the way while you work!!
E-mail me with any questions or for other Pics.
ronzara@hotmail.com
Thanks, RZ
