I have used the rubber cap. They crack after a year or so. I now use a 1/2" oil passage plug. Sand the outside of the plug and inside of the water outlet. Smear both with JB weld and drive in. Works great.
http://
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
