  #76 (permalink)
Old 04-24-2016, 05:44 AM
Paintwerks Paintwerks is offline
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Originally Posted by mudbrick View Post
Another snag has reared its head....its been so long since body came off, tried to put back on and the fiberglass supports that are glued to nose sit "inside" (>10mm) instead of "outside" radiator/nose chassis panels (if that makes any sense) Rad and all other front end panels are in place Has anyone else had this issue?
I had exactly the same problem. No amount of pushing and levering could get the brackets to move across. In desperation, I ended up cutting off those brackets, and only then could we get the body back on.
Fortunately, I had a spare pair of brackets so I'll glue those back on. Speak with Wazza about it. I'm sure there's an easy fix for this that doesn't involve cutting off the brackets!
www.paintwerks.com.au
