04-25-2016, 08:21 AM
Ny
Cobra Make, Engine: Superformance #2660, FE-406
Originally Posted by PurpleVenom
Will usually take about two of the small bottles. So, to cover bases, if you are not switching types (DOT 3 to 5 or DOT 3 to DOT 4 synthetic) then no worries, flush until new fluid comes through. Otherwise, you will need to use de-natured alcohol to flush the old fluid, then the new fluid to flush out the alcohol. Anyway, just make sure not to mix the two types.
I'm experienced on the "how's", have done several, just a capacity query. Probably use a couple fresh cans of Super Blue I've had.
The older I get, the faster I was.
