  #35 (permalink)
Old 04-26-2016, 11:35 PM
mickieb49 mickieb49 is offline
Cobra Make, Engine: MICKIEBEEZ COBIA
Originally Posted by David Hodgson View Post
Mick, I'm assuming the bonnet scoop is that size and shape because its needed to cover a tall engine?
Hi David,
Yes it is mate, allowing the 100mm ground clearance , with this bonnet scoop I will have 10mm to play with above the carbys. Already had to raise the whole bonnet and nose section by 100mm to achieve this, much more then it would just look way too wrong.
Im hoping I have enough now, also going to have to make a custom Air box, should prove to be interesting, add that with the oil tank ( dry sump) oil cooler radiator and radiator, real estate is becoming a premium in such a small front end.
