  #65 (permalink)
Old 04-28-2016, 03:56 AM
SydneyChris SydneyChris is offline
Two cents worth as a design engineer... Id repeat what Mike said.. under drive the PS pump, there is little assistance required at speed, use a synthetic fluid (I had heard one P Brock used a Mobil fork lift trans fluid on a Monaro he raced in Targa) and add a cooler or even a simple cooling loop of exposed / finned alloy tube to increase the volume of fluid in the system all of which will support heat dissipation.
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
