Originally Posted by Bob Hess
Turn the black plastic knob CCW. When you do this, the chrome collar at the bottom of the plastic piece will rotate on some threads and allow you to set the shift pattern in any direction you wish. Jam the two pieces together to tighten (GENTLY!).
How much force is required here? I'm turning pretty hard, to the point where it feels like I could do damage and I don't want to give it much extra.
Do I need a tool?
When you say jam to tighten, are you talking about the plastic and the chrome collar? These squeeze together?
It appears to look like its just screwed on but that the tight position is 90 degrees out off.
