Did you have a pedal max travel stop installed ? The HTOB's don't have an internal stop, so pushing the pedal too far will extend the piston past the seal and leak or dump most of fluid. It happened to me, but I knew better, so shame on me.
I converted to external slave (the purple one from Speedway Motors) a throwout arm and a clutch disc from McLeod.
I'll try to find pics.
The HTOB's work better IMHO, (less pedal pressure ) but must be set-up as per instructions or you will have problems.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Reason: add mcleod
