Thread: Setting Timing
  #74 (permalink)
Old 05-05-2016, 07:04 PM
patrickt patrickt is offline
Originally Posted by Large Arbor View Post
Black one, it was the same size that came out before. Also using the silver springs.
Phil
The black one limits you to 18 degrees, so if you want to shoot for 35 degrees all in, your idle timing will be 17 degrees. If you find you want less idle timing, like me, then you're going to have to change your bushing so the total comes out to the sum that you want. The bushing is easily changed, just Google a vid for it on YouTube. I use the silver bushing, that limits the advance to 25 degrees, and I have 10 degrees at idle, so my all in timing is 35 degrees.
