There is also a heat shield you can buy to help keep the switch on the master cylinder from failing (too close to the headers apparently). I have an early backdraft (#157) and it did not come with the shield - my switch failed also and i put the shield on. I ended up also installing a mechanical backup as well just to be safe.
