Old 05-11-2016, 11:39 AM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
If you want a pressure gauge on the dash, then you will need an isolater on the firewall. This is a must as it keeps fuel out of the cockpit. The isolater is basically a diaphragm filled with glycol (anitifreeze) that receives the fuel pressure from your source and transfers it to the gauge through the firewall. DO NOT try connecting direct fuel pressure through your firewall and to the gauge!
