Old 05-12-2016, 09:22 AM
lippy lippy is offline
Originally Posted by A98Coupe View Post
Jeff,
After reading Tom Kirkham's post last year I've gone down the same route as you, but I'm not finished with the installation yet. Your method for locking out the distributor looks far better than what MSD recommends. I wasn't looking forward to pulling the gear off the shaft! Great post and gives me some good retard map info. to get started. You could also add a notch in the run retard curve at 1000rpm to help keep the rpm steady - as per Tom's previous post.
Regards
Stuart
Once you figure it out it's really easy to adjust the timing and experiment. I started out by making the vacuum retard curve a constant -10 degrees just to make sure everything worked properly. Once I felt good about that I started adding timing on the vacuum curve. Of course you don't want too much advance, and that was the approach I took.
