No work has been performed on the seat but some progress was made. The ride height turned out to be way off so the front was dropped 1/2" and the rear was raised 3/4" to get it back close to spec. Tire pressure was changed from 25psi cold down to 22psi cold. Had it out last night for a good 70 mile spin and it road MUCH better. It is still bumpy at certain times but much of that could be contributed to the crappy roads. The greatest achievement was finally locating a squeak in the rear driver side that was driving me insane. It had gotten to the point where when you got in the car it would squeak if you shifted your weight sitting still......turned about to be the joint where the top a-arm comes out and attaches to the rear rotor and caliper.
