Old 05-15-2016, 04:48 PM
Danr55's Avatar
Danr55 Danr55 is offline
Default New Solution to an old problem
As some of you are aware, I've had issues with my alternator making a horrible noise when I start my car. I've tried tightening the belt, tried soaping the belt this morning (No Joy) Tried buying a belt the same size without the interupted teeth.. still no joy. So I sat down and looked the whole thing over again.. Gues what? The belt that is the right size for the water pump and the crank pully is too small for the pully on the alternator. Bought a belt 1/8 inch wider without interupted teeth and problem solved. So, if you have March custom over-drive pulley on your alternator, make sure the belt fits the march pulley aand the waterpump and the crank pulley will handle it just fine..
Dan in Arizona
CCX3209
