Actually, nearly every time I pulled the distributor, the
oil drive came with it. I used a straw and slit it slightly and then pushed it down over the drive and then lowered it all into place in the
oil pump. Then I twisted the straw until if broke loose. So, the straw is used to put the
oil drive back. I have heard that tapping the side of the distributor will stop the oil drive from coming out.
Phil
