All my gauges are working except my fuel gauge so I removed it from my tank and was checking it's continuity etc. As it turns out I have a 22 gal fuel cell and I only put in two gallons which is hardly enough to move the needle. Gauge works fine because while I had it out and wired I rotated the cylinder so to move the float inside to different levels and my gauge reads correct. Just a little paranoid I guess.
Main body should be ready in a couple weeks (I hope) so I am going to start the body work on my doors, nose, and pontoons (which house my side pipes) and I am sending my side pipes off to be ceramic coated WHITE by Jet Hot in Oklahoma City. Seems as though things are moving albiet slowly.
Once I get my body back from the fabricator I can finalize my dash and door panels and get them off to upholstry. As with many projects you need one thing to finish the next etc. Patience Grasshopper as Mr. Miagi said.
"Let's roll"
"Be part of Something Good
