I believe your
oil pan will be fine but the problem may come in when you are in the corners and all the
oil is moving away from your pick up in your stock pan. I spun a Main bearing at Texas on the high banks using a stock pan. Never again. $500 for a race pan and about $8000 for a rebuild.
One of the first things they will check is your wheel bearings and ball joints. Make sure you don't have to much play in your wheels with them off the ground. Grab your tire at 3 and 9 oclock and see if you can detect any play between the wheel bearing and the hub.
