Originally Posted by jwd
I've installed at least a dozen LUK clutches in cars ranging from completely stock to 500+HP big block Corvettes. Never had a single problem with any of them. They are also the OEM supplier for the clutches used in Vipers and many other factory high performance cars.
Good. You should hear the stories about the scrap. Like having to set up portable lifts in a manufacturer's parking lot to replace clutch disks due to the dampening springs not being made to specs.
I've also installed many in factory cars. Not a problem, but if you deviate from factory specs, get a performance clutch.
