It can be rotated to the "conventional" location. There is a setscrew ("grubscrew") that prevents it from moving/rotating on the steering column. Take care to ensure you do not put to much tension on the wires. You may need to pull the wire harness feeding the switch to provide a little slack to accommodate the move.
rick@autoventureusa.net
