Old 05-12-2002, 12:27 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Not sure this helps or not as I'm not sure how Midstates attaches the sidepipe to the header.
While going through the Classic Roadsters sidepipe muffler swapout, I cut the muffler off in front and rear. Had the turnouts welded to the new mufflers, and a slip fit (3" ID) welded to the front of the muffler.
Now, I have a 4 into 1 "J" pipe. It attaches to the header with 4 bolts, and a 4 hole gasket in between. Slip the 3" ID muffler adapter over the 3" OD "J" pipe. Bolt the turnout up to the car.
Then I ran 3 self tapping sheet metal screws through the muffler & J pipe to hold it in alignment. Took assembled muffler & J pipe back off and into the welding shop for final assembly.
While you have the J pipe apart, now is a good time to have the inside ceramic coated for heat retention and rust protection.
Hope this helps.
