Not quite road legal yet. As I posted on the other thread, I had a charging problem - took the car to Charlie and he sorted it out quickly (wiring between the alternator and voltage regulator had a couple of leads swapped...if I was not color blind I would have noticed that when I pulled/replaced the voltage regulator!). There are a couple of other issues he is working (couple of small exhaust leaks at the header flange/head interface and a small
oil leak at the
oil cooler block adapter/block interface). Hope to get it back early this week...THEN....back to the DMV for the level 2/title/license.
I will be glad when I can finally drive the car!
