Old 05-22-2016, 08:05 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Default ICCARS - AC Cobra Manufacturers
The Chassis:-
All ICCARS chassis are a space frame chassis design that has very high torsional strength (over 9,350Nm) which is amongst the highest around. The space frame chassis requires to be panelled just like the original, however we can assist with supplying all of the necessary laser cut panels, or we can panel it for you prior to delivery.
Aluminium panels come standard, however we recommend using stainless steel panels as an option and for longevity (especially if you live near the coast). That beautiful finish and high tensile properties that stainless provides is a clear benefit, and we down size the sheet thickness so weight is not an issue. All panels are SIKA bonded and sealed riveted which adds additional strength to the overall chassis over and above the 9350Nm... This is one serious chassis.
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
