Old 05-23-2016, 06:33 AM
albanycobra's Avatar
albanycobra albanycobra is offline
I just had a look and it does give that impression but small print also says ignition modules need to be wired in so pretty close but not quite. I like the idea but at $2095 you can get a Motec M84 $1905.
Heres the best advice i can give with aftermarket ECU's. Find yourself a local tuner, ask around to see if he is any good. Then go see him and ask what ecu he likes to work with. Go buy that brand and install what ever brand that is.
Honestly this will get you the best result. A super expensive computer will still drive like a dog with a bad tune and the cheapest of ECU's can run like a dream if tuned correctly.
2nd hand Ecu's are ok if you know the history or the person selling it, some are locked and some like Microtech if set up for a rotary cant be changed to suit a V8 for example. So you need to know what you want and ask right the questions..
