05-26-2016, 04:56 PM
KY
I would base the decision on what clutch disc material you're using.
If you have an organic disc or something similarly mild, then you can use a pilot bushing. If you have a sintered iron/aluminum/Kevlar disc, then I would recommend a bearing.
The dust from the more aggressive disc materials can contaminate a bushing and cause premature wear.
