  #39 (permalink)
Old 05-30-2016, 06:11 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Originally Posted by DaveW View Post
Hi Will, or others,
Whats the purpose of the adjustable axle control rod brackets in this pic?. i.e the ladder of location holes,
I've seen this on some drag cars etc, but don't know why its there.
regards
Dave
Hey Dave, the reason for the series of holes is to allow for adjustment of the track rods in order to get the diff pinion to arc in perfect relationship to the spicer yolk on the tailshaft, i.e. think of a pendulum with it's two connecting rods tapered back up to the pivot centre and then imagine the base of the pendulum swinging in relation to the pivot centre - this is what you want your diff to do so that it does not actuate perpendicular to the spicer yolk (or transmission output) as that will load up the universal joints and create issues with the driveline function. The hole positions allows you to alter the top and bottom track rod arc points to the diff mounting brackets, thereby giving you the ability to set the diff pinion to the optimum pivot centre position.
Hope that explains it OK
P.S. I'm sure Deano could explain it better than me as he sets up sprint cars suspension all the time, but that's my best explanation
Regards
Wil
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
