  #177 (permalink)
Old 05-30-2016, 05:09 PM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Originally Posted by albanycobra View Post
Was thinking today this car needs a special motor, Im thinking a Windsor Clevor (Boss)type motor might be the go. I have built a lot of motors in my time but not a Clevor and my current 414ci Windsor is real nice in my 40 but the cam is to angry for nice cruising in a Cobra
Thinking CHI 3V heads, 427 stroker crank, Custom 8 stack intake, 427 Cobra valve covers.
Anyone know of any Dart / world or similar blocks laying around? or where the best place to buy a block from?
Hey Dave, I have just pieced together a 427W Clevor set up myself using a standard late model '97 351W roller block and Dot 4 Cast 4V closed chamber heads etc.. I had to use custom forged pistons to allow for the canted valves and to get the compression height of the piston to suit the 6.2" long rods with a 4.1" stroke crank. It took a bit of sorting but as I mentioned the std 351W block will get you to 427cubes and they are good for 650hp all day. What you will need to get with the CHI heads is an external thermostat block mount that runs 5/8" hoses from the front of the CHI heads to the thermostat housing - CHI sell these also. Custom inlet manifold only as you mentioned as Edelbrock make a non EFI manifold for this set up but you will need EFI for emissions.
That said how do you get something like that through emissions in W.A. Are they more relaxed on it than in other states or will this be a club rego thing where emissions are negated by virtue of the club rego system?
P.S. just remembered that if you do use a std block you will need to make some releif points on the bottom of the piston skirts for rod clearance - pre-assembly is a must IMHO.
Wil
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
