I am not sure I would use that exact engine because you are paying a lot of money for the sealed racing specs you do not need, but something with 400 hp is perfect depending on your tires. I would guess the RPM range kicks in a little higher up the RPM range, which makes them pretty nice to putt around in until you floor the car. Tuned correctly with EFI will help a lot also.
