Originally Posted by Armrer
Yep, the M-6007-X302B is the unit as you mentioned. 345 hp, call them for a dyno sheet to rpm/power spread. Great engine.
The T5 is a good call. V is right on that, looking back I would have picked it over the TKO 600.
The T5 world class is fine but the .64 overdrive puts many engines in a "no go" rev range at normal (65-80) MPH speeds where the TKO .82 allows use of fifth without lugging/bucking/being under the comfortable range of the engine.
Again, careful analysis of how and where you will be driving will help in proper powertrain selection.
The tires on your roller will be selected by the dealer. The factory provides no tires so request what you want and pay the difference to the dealer to bridge the gap from what they "give" you to what you really need.
