I also have a 3:31 rear with a .68 behind a Tremec TKO. The first 4 gears
are almost the same as a wide ratio toploader except for 1st which is lower
@ 2.95. I use it like a 4 speed with 5th just as an OD cruising gear that
results in a very quiet 2200 RPM at about 70MPH.
