Old 06-03-2016, 07:22 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Originally Posted by Gaz64 View Post
. . . Are the injectors in the middle where the Weber emulsion tube/main jet/air corrector would normally be?
Are the "mixture screws" on the outside for bypass air only, to balance the barrels at idle/lowspeed?
The injectors are buried inside the wells of the carb body. The "mixture screws" on the outside are functional, they are used as air bleeds to balance the barrels. Linkage is pure Weber.
www.65shlb.com
www.prdcrrct.com
