Old 05-12-2002, 09:14 PM
Cobra20646 Cobra20646 is offline
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Default You Too!!!
This is hard to believe, but I had just about the samething happen to me tonight. My wife and I drive about a half hour to visit our son and his wife. Temps today were mid eighties.
The trip was uneventfull..... normal even.
An hour or so later, we hear a thunder storm approaching, and my son suggests we take his car from the garage and move the cobra into it should it decide to rain.
Cobra starts right up and I pull from the drive way to the street so he can back from the garage. When I'm pulling in, the car acted like I stalled it....... just quit running. Starter motor turning over the engine, but it won't start. I finally use the starter motor to move the car the last ten feet into the garage.
After dinner, we go to the garage to see what the problem is. While stroking the accelerator, I can't see any gas from the accelerator pump. I pull the fuel line and try to blow air into the carb to see if the needle valve is open......... appears that both needle valves are stuck on their seats, as I can't get any air into the carb. Pull the top off the edelbrock and see that both fuel bowls are about bone dry..... but now I can blow air into the fuel intake and see the floats and needle valves doing their job, although one needle valve will stick closed, but a slightly stronger puff of air will open it up.
Next step, turn over the engine and see if any fuel will flow from the mechanical fuel pump. Seems OK, but the pressure seems low, as I can cover the end of the fuel line with my thumb and stop all flow.
We put everything together and fire it up. Runs perfect. My son follows us home to make sure nothing unexpected happens. When I get her in the garage I again pull the fuel line and put my pressure gauge on it........ reads just a tad under 7 pounds, which is normal.
I'm stumped.........
I'm thinking vapor lock now too.
Anyone here explain exactly what vapor lock is and what it affects? Does a vapor (gas) get into the fuel pump and prevent any liquid from being pushed through it?
Under hood temps were quite warm, but water and oil temps were "normal" for my car, 180 and 160, and I've run the car through hot summer days many times before and never experienced anything like this.
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
