Old 06-04-2016, 01:49 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Cobra Make & Engine: 1989 KCC from South Africa Right Hand Drive
Listen ...you can totally make a Cobra dry inside.........
the water generally runs down the windscreen posts into the foot wells. So seal those with some of that sticky black stuff you can get from a body shop, or silicone.
When you have the side-screens on you should fold the side wings flat or else they cause a vacuum behind them and suck the screens out. Also the water runs forwards into the cockpit from the top of the rear cowl......that,s why the top has to have a rubber seal at the rear .
