Old 06-08-2016, 11:48 AM
patrickt patrickt is online now
Originally Posted by Texasdoc View Post
I thought about that. If I add grease to the fitting on the u joint, will that grease all four lobes? Can I grease it installed or should I remove the while driveshaft from the car?
Here, watch this video from Spicer on lubing your u-joints. You want to pump the grease until you clearly purge all four seals. Do not stop at the first. Go here: http://ujoint.kickme.to
