Old 06-08-2016, 05:38 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Jac Mac View Post
If you have a bronze spigot bearing/bush in the back of the crankshaft it could be dry, they make this sort of sound during clutch release as you drive off.
Not necessarily during clutch application.
They generally make noise anytime the input shaft is slower than the crankshaft, especially if the input shaft is stationary, as clutch in, in gear.
Once the clutch is fully engaged, the noise stops.
